Push hard and live
Im pretty sure wheel has to come off. I’ve done several, but memory a bit clotted.
EL002 COLUMN SWITCH - 2 HEADLIGHT CARS
There are some on which the black plastic part wraps around the column, and some where it is U shaped, and thus if you can get an Allen wrench in, you can get it off without removing the the wheel. You have to unhook the return spring too, which is wrapped around.
