1 - 20 of 25 Posts
Hi everybody,
I don´t have the repeator lights on my car.
That´s because in it´s day as a daily driver my dad sealed the holes to prevent rust.
I´ve of course seen lots of pictures, but is there a print of some kind that has measurements?
Lots to do :D
Tia
Jan
I always thought that the side marker lights on Alfas don't blink with the turn signal, but just turn on with the headlights/taillights. When I removed mine, the wires were the same color as the taillight wires - yellow.
If they were indeed blanked out, you should be able to see the welding from the inside of the fender. No one would go through the trouble of making the inside look good. You may have to remove the flap in front of the wheel to see inside.
That is because that the US laws prescribes that you call side markers. Many European contries prescribes repeaters, or side turning signal flashers. Repeaters are connected to the front turningssignal lights hence the name.
Erik
Discussion Starter · #7 ·
Thanks a lot guys :)
OK, it´s all inside the flap?
Yeah there should be marks on the inside of course :eek:
Great, I´ve missed having them and I know they are somewhere but just in case I bought new ones :D
Jan
Discussion Starter · #9 ·
OK, I´ve finally got going and fixing the repeator lights.
The wire was, as iachella said, yellow.
Is the wire a single core or is it two?
I´m no electrician but I suppose there is some kind of ground there?
It seems to have seen it´s day by now :D
/J
The light assembly itself grounds directly to the body, if I recall correctly.
Discussion Starter · #11 ·
OK, but this is the reproduction repeator I got from Highwood.
Do I just cut the wire and connect it to the repeator? I thought it would ground to the connector, but as seen in the pic below it doesn´t look like it computes with the connector in my previous post.
/J
If it is a turn signal in place of the side marker, it still has to be a side marker. It appears to need both the side marker wire (yellow) and the turn signal wire (blue and blue/black).
I don't know if there are two bulbs in there, or one that will go dark with the turn signal pulse when running lights are on.
In Europe we don't have to have side markers on neither old or new cars. So TNT can just change or fit a repeater indicator to his front wings.
Only buses and trucks needs side markers over here.
Erik
It looks like the reproduction repeater may require a separate ground wire (because of the plastic bulb holder). Can you remove the bulb holder from the repeater and post a picture? Also, how many electrical connections are on the bottom of the bulb; one or two?
Discussion Starter · #15 ·
Wow, I just saw a pic of the repeator on classic alfa, and that one only has one connection.
Weird.
Thanks papajam, I´ll check it out and post some pics.
Discussion Starter · #16 ·
It seems to use both connectors. But the yellow wire is a single wire or?
The connector attached to the yellow wire, what is it? Or has it erroded during the years of none use. The cable boots seem to indicate that ;)
/J
Ask Chris from Highwood how to connect the wire. If your GT is a US version the light was a side marker, if its a Euro version its a indicator repeater from the front indicator. The bulb connect is for a metal less bulb all glass with two small metal leads. It probably gets earth via the light base and nut holding it to the front wing.
Erik
I've just checked Highwoodalfa's web site and it seems that both the early long repeater and the later round one have an earth lead, though the early long one only have the two connectors.
So you need an earth lead from one of the connectors plus the existing one (yellow) if its still is life.
Erik
Well, since there is only one power wire feeding the bulb, with the original ground being through the housing, it does not matter if the light is a side marker or repeater. But with a plastic bulb holder, the 2nd bulb connector needs to be a ground. A short jumper wire from this connector to the light assembly mounting stud should do nicely.
1 - 20 of 25 Posts
