1 - 2 of 2 Posts
Has anybody out there removed the rear wheel hubs on a Milano/75? I am installing some custom wheel spacers from Serpent and have to put on longer studs. Does anybody know how to do this? Is it necessary to disconnect the axles at the hub first? Any help would be greatly appreciated.
Thanks, Steve
I have done this, I think you are going to need the stud puller and maybe the bearing puller. I think the part that connects to the axle comes out when you take the nut off, but them the bearings are tight against the part the connects to the wheel, you need a special tool or a big hammer to get it off, and sometimes that screws up the bearings, I have the bearing tool, if it comes to that.
1 - 2 of 2 Posts
