Does anyone know if, by raising the engine off the mounts alittle, can the rod bearing caps be removed from all 4 of the pistons?
Yes. Un-do the motor mounts. I shim with a couple of old brake pads under the mounts, unbolt the oil pan and unbolt the oil pump and remove it with the oil pan. you can then get to all of the rod caps. I have done this plenty of times.
Good luck.
