Hello all,
How do you remove the cover on the water pump side of the engine? I removed all the bolts including the few that connect the bottom side to the oil pan. Should it slide out off the tip of the crank shaft or does the whole oil pan have to come off?
Thanks!
Sorry Sean, but I've only assembled one of these engines and don't remember any more than is in the book. Remember to take all of the bolts out over near the power steering pump and from the pan, and you should have the front cover removable. Remember it houses the front oil seal, which might bind a bit on the crank surfaces. And the pan might be glued to the front cover with who knows what. The previous owner is always an idiot, even it if was me. (It wasn't in this case, if the reader might be wondering....)
