1 - 5 of 5 Posts
I'm trying to remove the door panels so I can replace the side mirrors and cannot get the door panel off. I've remove the screws including the one screw on the long door handle. I've also removed the door handle (opens the door)and the window handle. Any ideas?
There are three screws in the arm rest. Two should be visible in the horizontal slot (where a plastic chrome strip fits), the third is behind the triangular silver piece still in place in your photo. Reach behind where that silver plastic piece is located and there'll be a 'finger hole' to push it out.
You then might want to use a door panel removal tool. There are some plastic clips that are a press fit into sockets in the door. Gently pry them out - they just snap back in when you reinstall the door panel.
1 - 5 of 5 Posts
