Window Trim Removal
Roberto,
It's been a long time since I've done this, and it was a '68, not a '72, but see if this helps: Wind the window all the way down into the door and look inside the window channel from the top. At both ends of the trim and somewhere in the center, you should see a tab with a phillips head screw which holds the trim to the door. The back one and maybe the center one is accessible from the top, but you will have to remove the door panel to get to the front screw, located below the vent window. You may have to unbolt the winder mechanism and drop the window down to get to the center screw, I don't remember.
Hope this helps.
Bob A.
Paducah KY
Roberto,
Hope this helps.
Bob A.
Paducah KY
