Tom,
Could be an ATF drip from the transmission, but more likely from the power steering boot on that side. Have you checked the power steering fluid level?
ATF is used in the transmisson just an FYI!
Could be a number of things. transmission seal leak? Steering rack leak (also uses ATF not steering fluid).
Check steering boots for leakage, check large bango fitting on the steering rack, can come loose and leak or washer is bad, check for leakage around intermediate shaft and left inner axel. Sometimes the O-rings can go bad and leak!
Check the Steering fluid tank located behind false fire wall on left side for low fluid, check under car for return line and see if if is leaking at all. This is the U tube located under the driver seat mount to the bottom of the sheet metal, There are two lines coming from the tank and sometime can leak or U tube is rusted and can leak.
Try that.
Jason
Recommneded ATF fluid: AGIP (of course), Castrol or Valvoline Dexron III, Mercon IV rated or better. (stay away from Mobil 1 Synthetic) Of course there are plenty more but I find these to be the best for off the shelf.
I use PENTOSIN ATF 1 or Lubro-Moly (German Import stuff)
For AGIP products either go to Amercianagip.com (same stuff as the Italian)
