1 - 2 of 2 Posts
74 Spider 78 Spider 84 Spider
Removed the leaking slave on my 78 Spider. When I took the slave apart I only found 1 seal. All pictures I've seen of the piston inside the slave shows 2 seals. It's marked ATE. Is it possible this slave was not for this car but somehow made to work?
I have a brand new slave from CA on the way but the bore on this one is still very smooth so I would like to rebuild as a spare.
ive seen both. Order the rebuild kit if you can find it and rebuild it!
1 - 2 of 2 Posts
