1 - 5 of 5 Posts
Dear Alfisti,
I noticed that both rear wheels have a little play when the car is on the jacks rocking them to any direction. It is similar like the front wheels play when the bearings are not adequate tightened/adjusted. Of course rear bearings are fixed, so no play adjustement is possible. Also there is no any noise or vibration as I had greased them during restoration. I am afraid that most probably would be replaced having already excessive play. Any idea if I am correct or not?
Are they moving just in and out, could be your t bar has slack either at the trunions or at the diff mount this would mean the complete axle is moving side to side.
Had the same question. Was told that the limited slip versions have pöay and it's OK
Sorry but some characters are unreadable. However I have limited slip differential and now as I can think ....yes it could be an explanation.
No they don't move in-out. All bushes and rubbers are replaced. The movement is radial if I express correct my self.
1 - 5 of 5 Posts
