Sure Guilia, come on over and we'll show you some good ol southern hospitality. Since I have the majority of 105's or for that matter any Alfa's in the area the tool wouldn't be cost effective for me. That is why I want to find a used lathe on craigslist and start makeing some of this stuff. Althouh from looking at your photo does the tool work by bolting the flange on the bottom(I can see some nuts wired to the flange) to the studs on the backing plate and then the tube is threaded to tighten down on the tube and pull the bearing off. Does it take both the bearing and retainer off at the same time. Does the backing plate come under any stress? Thanks, just trying to figure out from the photo how the tool works.
AlfaP, are you taking the studs off the backing plate because unless you can show me a photo of a bearing separator with the tapered ends behind the retaining ring much less behind the bearing itself I don't see how one would get around the studs. Call me stupid, a photo sure would help though.
Hi gigem75
You are correct.
The 4 nuts,wired to the tool,are used for attaching the backing plate to the tool.
I usually smash off the lock ring with a hammer and chisel,and then withdraw the bearing with the tool.
Refitting the bearing and retainer is done with the hollow tube pictured.
2 litre axles have a shrink ring,and all others have a threaded lock ring.
Job takes about 5-10 minutes with the special tools,after the axle is removed
I guess my customers are lucky that I have the tool. 2 of each actually.
Might take a pic later with the removing tool attached to the axle to give you a better idea.
Robert
