My Pilgrim's Progress is proceeding to the rear suspension. I have the swing arms off and the old shocks and springs out.
On my 71 spider somewhere in its ("recent") past the rear springs had been replaced with IAP's while the front springs remained stock. This explains the "speedboat" effect with the nose being so much higher than the tail.
Now it's time to replace the springs. I purchased a set of slightly used sport springs and discovered, interestingly enough that while the fronts are shorter than the originals, the rears that came with the set appear to be stock springs in that they're taller, less tightly wound, and lighter gauge than the (confirmed) IAP rear springs that were on the car.
So it's decision time as to how to mix and match the springs. I seem to recall reading (but can't find right now) that some people prefer the stock rear spring/IAP shorter front spring to the IAP rear/IAP front arrangement.
I'm definitely going to use the IAP fronts, but which are the best to use on the back?
I have four conflicting logic patterns going on in my head.
1. IAP Sport front and IAP Sport rear; matched set.
2. IAP Sport front and the rear springs that came with them when I bought them; matched set (but different match criteria).
3. Best handling: IAP fronts and ?
4. Best ride rake without the speedboat nose effect: IAP fronts and ?
Below is a picture of the springs. Note that the 'stock' rear springs are red because they were red when I received them, but I've since repainted them. the shorter IAP rears have the black vertical stripe on them (looks like a shadow in the picture). They're confirmed IAP's since one of them still had an IAP part label on it.
Oh, if it matters, the shocks are Koni Reds.
Advice? Opinions? Help? Thanks!
