GTV6 back seat removal
Thank-you very much for your response to my back seat inquiry. Yes, the base is held to the car by two prongs, opposite ends of the base and forward, that push through retaining grommets in the seat riser, allowing the base to just pry up forward & lift out. The back is held in with two metal strap type tabs on the outside ends, which index into attatched slots on the inner wheelwell. It is also held in with two metal studs in the very back and upper, or shoulder area. These studs drop through slots in the crossmember between tank and passanger compartment. Both studs were loose and missing their plastic or rubber sleeves. The repair, with the help of my wife, took 20 minutes, and sent us back down 128 in the tight quiet GTV6 it had always been. Thank-you very much for your help!
Fred GTV6 VROOMA
