1 - 2 of 2 Posts
Finally got my engine up and running yesterday after bending a few valves last month!!!!! Man did I miss that beautiful v6 sound
Maybe I was just tired from working on the car all day but I could not get the rear passenger motor mount out!! Is there a trick to it? Will have to take a closer look, maybe the bracket will have to come off in order to slide the new mount in.
With nuts off both motor mount studs, three bolts out of rear mount in subframe, upper dog bone mount out of the way, radiator top support bracket bolts out, four lower bolts out of right strut mount so axle will give, and air cleaner cover loose to protect inlet hose flex coupling you can jack engine enough to slip rear mount forward out of sub frame. Watch alternator against top radiator hose and radiator outlet when jacking engine.
1 - 2 of 2 Posts
