hi, am trying to disassemble the complete rear dedion sub-assembly and having removed the CV joints either side (had loosened most of the bolts when car was on ground) I have now turned my attention to removing the calipers. My goal is to separate all the components, refurbish and reassemble.
I have read on a previous related post that the way to do this is to remove the pads first, remove the rotors and slide them out before removing the caliper as the caliper bolts cannot be freed due to the rotor being in the way.
I kind of understand the principle. my issue is the brakes appear seized on driver side, and unable to move calipers hence pads. If I do manage to free them tomorrow, how would the pads come out ? surely the rotor is blocking their exit path?
appreciate any precise insights. I've dowsed all the bolts in WD40 equivalent to soak in overnight, as one of the rotor bolts was not budging. I will get them out tomorrow by hook or crook, just might get a following wind if someone can steer me in the right direction. cheers.
https://flic.kr/p/2kHBuUy
