Does anyone know what the free space between the canvas strap and axle is supposed to be? assuming the car is standing properly, tank half full, spare tyre in etc.
I mounted two a while ago and noticed a difference of 2 -3 cm's between them. My gut tells me it should be about 5 cm's measured from the underside of the axle until the bottom of the small circle the strap forms.
thx,
George
Alfa Romeo's "Technical Characteristics and Principal Inspection Specifications" (Pub. #912) give a measurement of 8 mm +/- 5mm between the rubber stop and the rear axle, using weights of 50 kg on each seat and 25 kg in each foot space (as if 4 adults weighing 75 kg each were in the car). This loaded measurement is a better measurement than the free space between the axle and the strap.
You may have noticed that the inner and outer straps have different length. Did you by any chance use 2 inner straps on one side and 2 outer straps on the other?
