Re: used gtv6 swaybars for sale (verde or aftermarket o.k.)??
Anyone have a front Verde swaybar or any aftermarket used swaybars for sale? I need to install a set of Koni Yellow's I have been sitting on and its prime time to upgrade the front bar while I'm at it. A front rear set is good too if the price is reasonable.
Thanks in advance,
Adam
Adam,
The front swaybar can be installed anytime, easily, by 1 person.
Also - the Milano rear swaybars are smaller than the GTV6 bars. If you're going for stiffer bars then leave your stock rear bar in place. If memory serves correctly, the GTV6 rear bar is 22mm and the Milano rear is 20mm.
For the front:
Your stock GTV6 swaybar for the front is 20mm. You're going to want a late Verde (24.5mm) bar rather than early (22mm).
If you're keeping stock torsion bars up front, my suggestion would be don't go (much) bigger than a Verde bar or else you'll be putting serious unnecessary stresses on the chassis mount points.
Understood Rob.
Do seem to recall hearing about the rear bar issue you mentioned.
Thank you as usual for your insight...always appreciated.
Hopefully someone will pop up with a late Verde bar soon....
Anyone?
Discussion Starter · #5 ·
Called Larry @ APE and he is checking for me!!
Discussion Starter · #7 ·
Thanks 'Spiderrey'...
In good shape?
The larger of the two designs?
Mounting hardware?
What are you asking for it shipped to Dallas?
Feel free to send me a private message...
Adam
