1 - 1 of 1 Posts
Hi all,
I installed a new head unit, kicker speakers and amp, using the existing 6 pin radio harness connector for constant power, switched power, and ground. However... the two power leads don’t have power with ignition on or off. I have been parsing through papajam’s diagrams to see where these red and red/black wires go so I can trace the fault. Does anyone know where they are supposed to be getting power from? I followed the red one in the diagram to a pink wire on terminal 1 on the brown fused connector in the fuse box, but had no continuity between the two connectors when I checked, nor could I confirm they were physically connected. Any help is appreciated. I suppose the alternative is tying in the power and ground to other working sources like cig lighter or whatever.
1641551
1641552
1 - 1 of 1 Posts
