As we all know the radio in the 164 is supposed to stay on until you remove the key and mine has always worked as designed until about a week ago. Now it turns off with the key. While this not a big deal, it concerns me in that is probably indicating something is starting to go bad. Does anyone know how this circuit works and what would make it fail?
Moderator
Does your door chime work? The micro switch in ignition switch works door chime and grounds radio power relay.
See radio wiring page 640 in wiring book.
Sometimes mine leaves the radio on and sometimes it cuts right out when I turn off the key. Even when on, the slightest bump of the key cuts the radio off. I just assumed it was worn down now.
Discussion Starter · #4 ·
Haven't paid much attention to door chimes. I'll check them out tomorrow. I've been suspicious about the ignition switch for a couple of months as I've had a couple of instances where it wouldn't start. Then after it sits for awhile it fires right up and runs and starts great.
If it cranks but won't start, it may be the fuel line inside the tank.
