my 92 L does just exactly what alot of yours do. overheats after a bit of driving.
heres what i do know:
1. the fan DOES NOT work. i have it wired to 'low' speed and doesnt really do the trick. how can i rig it to work on 'high'?
2. it has an old water pump
3. the radiator COULD BE clogged
4. the coolant reservoir has a crack a leaky crack (new part is on its way to my front door)
5. it didnt get hot near as bad untill i blocked off the heater core
so i have a few questions.
the first one is, is there a high flow radiator that is fairly easily swapped in? is there a post on that?
2. can someone point to the direction of the post on temp switch and wiring and fan issues?
thanks
thanks
