Working on the project from hell. Replacing the condenser on my 1973 GtV6 and putting a new radiator in. Finally got the condenser but potting in the radiator in encountered a un forseen problem. I have pulled the radiator out before and normally it is a piece of cake. Under normal circumstances you just put the bolt tha is centered on top of the radiator in and that is it. In my case the bolt screws into a nut that is tack welded in the radiator support frame broke loose loose so I cannot tighten the bolt. Any ideas?
