Race parts for sale
Trying to clean out shop of all old race spares & parts if you want info pics send email direct! Please serious buyers only. Will delete from list as sold or add as “stuff” is identified & pictured. Lots of things to clean out. Much of fabricated parts are last available!
10/10/07 update:
Items in red are sold!
Special racing TZ/SZ 22/30 input shaft.
This is NOT a standard set of input gears (which are 22/31), on TZ/SZ and 102 5 speed transmissions, as well as "split case" 4 speeds from 101 cars...
For Sale is a rare 22/30 Input shaft & 4th gear removed from Autodelta transmission.
Both gears are perfect.
Input shaft is gundrilled (12mmx110mm) for strength & less weight. The matching layshaft 4th gear is back cut and drilled for less weight.
Putting on Ebay if not sold this week.
Make reasonable offer.
105/115 Dropped Spindles (1.25 inch drop) these are early uprights that has the small brake bolt spacing, with steering arm adjusted for increased
Ackerman & to eliminate bump steer
Brembo Aluminum brakes to fit above (narrowed for unvented rotor)
Very good cond. Ready to bolt on. No pads. $140.00
115 Dropped Spindles (1 inch drop) (uses wide bolt spacing Ate brakes) Steering arm adjusted for more Ackerman & to eliminate bump steer $450.00
101/105 race flywheel complete with 5.5 inch Tilton clutch. Rated for 180-200 lb ft torque. Total weight of assembly is 11 lb. 11 oz (for 105or 110 tooth ringgear 1300/1600/1750) Not for Street! Complete Flywheel, Tilton clutch, Disk, Modified throw out bearing & adaptor to properly position throw out bearing.
116 Racing clutch assembly. Last of RJR 5.5 inch triple disk Tilton units. Complete with 3 new disk, comes with all components to install. Weight of flywheel & clutch with disk, 8 lbs. Inc. new throw out bearing, new slave cyl. cover etc. In unfinished RJR project, never used.
Transaxle, Close ratio, lightened gears, 4 disk LSD built for my tube frame RJR project, never used. Ratios 2.78/1.72/1.38/1.04/.95
LSD for 101/105 type. 4 disk set up LSD. Inc. axles, for late 1300/1600/1750 rear ends. Fits smaller type ring & pinions. Ony one left $1,000.00
116 Alfetta type Dropped Spindles (dropped 1.25 inches) Steering arm modified for more Ackerman & to eliminate bump steer (this is small spindle version)
116 Milano/GTV6 Dropped Spindles (dropped 1.25 inch) Steering arm modified for more Ackerman & to eliminate bump steer
116 Milano/GTV6 Dropped Spindles (dropped .8 inch to fit in 15" wheels). Steering arm modified for more Ackerman & to eliminate bump steer $500.00
3.0 liter 11.85 to 1 compression, full race cams, ported heads, fresh everything. Complete from oil pan to cam covers. No FI or Distributor. Build sheet available $4.500.00
Modified RJR Distributor. Mercedes distributor machined to fit 12V V6. Modified advance to work in HP Alfa V6. Will trigger any Crane or MSD ignition system, and trigger any FI system including Bosch. Uses same Dist. Cap as Alfa unit. $600.00
3.0 liter 10.35 to 1 compression, track /street cams, ported heads, new everything. Complete from oil pan to cam covers. No FI or Distributor. Build sheet available
10/10/07 update:
