on a 2.5 you'd likely get a mild increase of power over ~4000rpm or so. some say they are good for ~10hp+ on a 3.0L, but on a 2.5L probably realistically 7-8hp. The 164s cams also only very slightly affect the low end rpm band, so they are an excellent 'streetable' upgrade. When installing a different set of cams be sure to check ALL valve clearances, as you may have to buy a shim kit for the intakes. Also if your previous cam failed, your lifters should (MUST!) be checked for scoring to ensure the new cam will not be ruined. The alfa V6 is hard on cams...
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Alfa Romeo Forums
