Hello all.........
I have adjusted the front wheels to to a -1.0 camber. Seems okay but does anyone have any suggestions, thoughts our advise?
I'm working on it tonight
Regards
michael:(
One degree negative camber may be a bit much if the car is a daily driver. The inside shoulders of the front tires will wear out quite a bit faster than the outside. But the handling will be much improved (less understeer). Then again, just rotate the tires every other oil change. :D
If you drive the car hard at all the tire wear will even out. I have mine setup with even more camber but the way I drive the tires wear even.
