usually it's because of non use, creating corrosion, but that's not the case with you I'm sure. I guess the rubber rings go bad as well, I have successfully rebuilt multiple calipers with the kits from IAP
Not sure where you got that info but it's not true, at least not for for "newer" Alfas. Maybe it makes a difference for the really old stuff, Mongo dunno. Anyway, Bianchi's got an '84 and it's fully compatible with any standard DOT3 or DOT4 fluid.I do hope you are not using American brake fluids that eat thing up. Most Alfa brake systems best use LMA Castrol brake fluid.
All the stuff that forms the other 364 days and doesn't get flushed out as it is not suspended in the fluid but already attached to the piston below the seal.i change the fuild every year...
There's your problem. Flush out the synthetic fluid.i use prestone syn. brake fuild, anyway. i am at work for the next 15 mins. a soon as i get home, i am removing the rear calipers and cleaning them/rebilding them
I'm telling you, man...if both sides started dragging at the same time, it's unlikely to be the calipers: both calipers wouldn't have gone bad at the same time. Look at things that would affect both sides in the rear: the hose or the proportioning valve for starters.86 spider.. the inside of the caliper where ok.. just a little rust below the dust rubber.. got some 1000 wet / dry soaked it in brake fluid, ckeaned it up.pistons where ok.. strange.. but that was only the pass. side, will do the drivers side in the morning, before i go to work.. after i rebuilt the pass. side.. checked it out.. pistons were moving.lots of brake pad left..
Yes,, **** marketeers! Should have named one of them something that didn't start with an S!twoliterlover, not sure what to tell you other than you're wrong. Alfa brake parts can handle standard brake fluids: check your owner's manual. I think you're thinking of the old British Girling natural rubber crap that used mineral oil or somesuch.
LMA is good stuff but not a requirement. For the record I haven't had a failed rubber part in the Spider brake system in ten years and I'm not particularly choosy about my DOT4 brand, I just flush it every two years.
Brian: "synthetic" is just a marketing term when it comes to some DOT 4s. You're thinking of DOT 5 silicone, which should definitely be avoided.
Eric, very nice summary. Another thing to look for is whether the comp ports in the master cylinder are restricted. If something is holding the brake pedal down, like a poorly adjusted lamp switch, then the MC piston won't fully return home and a seal can cover this small port that normally allows fluid to return to the reservoir. If you loosen the MC from the booster and a previously stuck caliper is then free, that's were the problem lies.Another part of the hydraulic system that can cause dragging brakes is a flex hose with an internal failure such that a flap of rubber/fabric acts like a one-way valve or severe restriction to fluid flow.
