I have fixed the fork piece too the door handle. I put the door all back together and now I can't figure out why the door handle is lose and feels free. I checked the spring that goes against the handle and the door and I was wondering if anyone would have a suggestion for something I could be missing or not doing correctly.
Can we make assumption that it opens door? If neither end of spring in arm rest broken you didn't quite install inner handle, spring and pin with screw and retainer correctly. It can be tricky and kinda hard to explain it. You have to see and do it to get spring tension to hold handle in retracted position.
It helps to sit there and try to visualize just how it works before attempting to reassembly these darn mechanisms. This "visualization timeout" really helps in the long run.
