I decided to pull the transmission on my 85 Spider Veloce. This is a carryover thread from where I went through every thing from a bad pivot arm and the replacement of all of the clutch hydraulics(see here). I had been noticing a rattle when I depressed the clutch and suspected the throwout bearing was bad. Now I cant get into gear from a stop with the engine running. So pulling the trans.
Here are my first shots. did the console
Then the exhaust connections and hangers
Then the crossbar and here I think I have a tip,.. One bolt is hard to reach under the heat shield so I think I will leave it in and just swivel this piece out of the way. I think It will make this easier to put back.
On to the Propeller flange next
