Does anyone know an easy way to unbolt the propeller shaft from the rear of the engine, so I can pull it? My Chevy enthusiast friend seems to think that it sits in the splines(the splines on the shaft that are pressed into the bracket that bolts to the engine), and that we can convince them out by pulling the engine forward, even though the book clearly states that they need to be unbolted, and also why would there be bolts if it just sat in there? I'm sure the answer is no, but there can't be a trick or shortcut can there?
