In case anyone was wondering...here's a step by step of how I've pulled the steering wheels out of my '74 GTV as well as my '69 Spider.
The tools that I used were:
1/2" breaker bar
1/2" ratchet
small extension
27mm socket
Flat head screwdriver
Dental pick
Wheel puller with 5/8" socket and piece of 1/8" steel strap to use to fit over top of steering tube.
Before and hopefully after pic
Pop off the center hub
Disconnect horn wires and pry back lock ring
Remove lock nut with 27mm socket and breaker bar. I had to use quite a bit of force to remove the lock nut.
1/2" breaker bar
1/2" ratchet
small extension
27mm socket
Dental pick
