Im almost done replacing the hood release assembly as mine had broken allowing the fusebox to dangle and vibrate.
Someone on here mentioned that the actual hood release cable is heat treated steel and i believe it. When i went to unbend the wire from the latch it just snapped off.
And of course the backup nylon pull was broken.
I fished a piece of bicycle wire cable in there for a backup wire, but i also realized that Alfa probably used plastic because the end if it will be very close to the back of the fuse box. So if you do replace the plastic wire with metal like i did keep it away from the fuses. I think i will leave the sheath on the wire, at least inside the cabin.
Overall not a bad job, i just need to attach the backup cable.
