1 - 2 of 2 Posts
what part?
because i have that new t5 in my alfa.. and need to build a new centre consul( if you want my t5 kit, and use the parts i provide , or show you what to get, you will not need to do this..i just want to do something diff.)i will be building a new dash/centre consul this is just a paper set up, clay molds later on.. lower pod, , L-R volt ,tach, speedo, oil temp. . top L-R fuel, oil pressure, water temp. the upper gauges will be set back so i can read all the gauges very easy.. sort of the way the honda cvicc has there set up on the instrument panel..2008-2011 cvicc.
what part?
this way none of the gauges will be hidden behind the steering wheel.. a little diff, than the honda.. all the guages will be inside the steering wheel.only the tach and speedo will stay alfa romeo stock.. all the rest vdo.
1 - 2 of 2 Posts
