Looking for a 1600 propshaft for my duetto. 8mm holes. The front part is so worn the driveline shop wants to cut it off and redo it, which is an option, but I'll ask first.
Thank you,
Wes
I believe that the front section is the same as GTs and Supers of the same era, if that's any help.
propshaft
70 mm propshafts/drivelines are available out of Europe from Alfa Service. I may end up just using the wider diameter one and drilling of the short portion of the driveline from out the back of the tranny.
Dear Sir,
yes we have a driveshaft with 8 mm holes. The outer diameter is 70 mm.
The driveshaft with outer diameter 57 mm and 8 mm holes is not in stock.
Kind Regards
Hi
I may have one but just to make sure , it has to be one with 8 mm holes ( I am asumming that this is at the front of the driveshaft ) and the outer diameter of the shaft has to be 57 mm
Thanks, Rick
