I finally found some time to work on Alfa....hhm more like spend some time in the trunk which was creepy & hilarious!
So my fuel pressure was just above 40psi but I was losing about 10 after 1 hour of sitting. So first thing I did I pulled the carpets from the trunk and check the visible vapor hoses and I am sure I did hear hissing sound from one of the 90deg 3/8” hose (as Charles mentioned on this link:
http://www.alfabb.com/bb/forums/164-168-1991-1995/170120-1991-164s-gasoline-smell.html ) . This explained the gas smell after 30 min of driving.
While there (in the trunk) I’ve decided to try pulling the fuel pump without tank dive in order to replace the infamous short hose and inspect other components.
Cut the fuel by pulling the fuel pump relay while car is running until engine died, disconnected the battery and went digging for pump. It took me about half an hour to get screws out. Considering sitting in the trunk and being in some weird yoga position – it wasn’t fun!
Just out of curiosity, I’ve tried to replace the short hose without pulling the entire pump out. Bit tricky but I did it. Then after about 15 minutes of finding the right angle since strange inside shape of the tank, I was able to pull the whole fuel pump assembly out (see my funky hand sketch below for obstacles in yellow).
I was expecting much dirtier filter but overall condition was very good, but still I’ve replaced all the rubber. Just FYI - I’ve found submersible fuel line (5/16” SAE30R10 by Gates) in local Napa store. Also to mention...while pulling the pump out, I accidentally disconnected the ‘soda straw’ but luckily ended up in my hand. Thanks to you guys & your postings about the soda straw, I was able to find upon assembling and actually see one of 8 holes where this straw belongs.
One thing I would like to point out is cleaning (to some degree) the fuel tank inside.
This is dangerous step (just like the whole project) since you are exposed to open tank and fuel fumes! So unless you know what you are doing – I’d highly recommend you DON’T do this whole project. With fuel tank empty, I was outside, with no source of any electrical components that may spark the fire and I used the Sun as my natural light source.
From the hole on top of the tank, I was able to see inside the tank. I’ve used small hose connected to siphon suction pump (anyone guess what kind of pump is this- shown on image?), in order to ‘blow/push’ all the dirt into one most visible corner. Then I’ve sucked that collected crap out with the pump as much as I could. The rest, I used the magnetic extension tool/screwdriver for pickup metal shavings. Took me about 4 pickups and each time I’ve had this much (see image below) of deposits picked up.
Placing the fuel pump assembly back into the tank was again bit tricky since the angle issue mentioned earlier and as shown on a hand sketch. After job was done, started the car with no problems, check the pressure and it was holding steady with slight drop after awhile. No more problems starting the engine when warm!
Thanks for help!
Cheers,
Sasha
