In the past, I have carefully pressurized the fuel tank with my air hose from the compressor regulated to about 10psi. Disconnect the hose at the pump and put it in an empty beer bottle. Push the fuel through and then reconnect hose to pump. If that doesn't work, try pressurizing while cranking. If it still won't pump, you might need to service the pump.
