Crank polished and balanced, oil passages drilled and tapped. 12 pound alloy flywheel dowelled to crank (new) New set Carillo rods- $2K Domestic shipping extra. Will confirm ring gear tooth count. Have new original style pressure plate that can go with if you want it. Contact Fred- [email protected] 13AFBDF9-F51C-4774-9327-1D8C1978CEEB.jpeg B45FA412-B7CC-49CD-B83B-71FFC30A91F3.jpeg E30BAEAE-7ABC-42CD-A43C-66A8D4E4C471.jpeg D40B6DA5-EFD0-4C20-9FD4-21CFB1F3ABD7.jpeg
If it helps I will break this up as follows- the crank $500.00 the Carrillo rods ( with Carr bolts, still sealed in their factory bags) $1,000.00 and the new alloy flywheel with pressure plate $650.00
Give it a day or two before you break up the set..
The beautifully polished, balanced, drilled and tapped and balanced 2.0L crank is still available for the very reasonable price of $500.00 plus shipping. The brand new Carillo rods are also still available for $1,000.00 including domestic priority postage. Don’t even think about revving your 2.0L motor much over about 6K rpm or running around a race track without these rods!
