1 - 2 of 2 Posts
Can someone recall off-hand where the power window circuits (particularly the fronts) ground in a Milano? Mine front windows move very slowly, & I suspect dirty gounds. I'm hoping someone can tell me where the ground is located so that I don't have to remove unnecessary interior trim just to trace the wires.
Hi Michael, under your dash next to your clutch pedal thier is a block of grounds you may find it easier to pop out your fuse box to get at them. Now I'm not sure that they are related to the windows but it is a good place to start. My windows along with pretty much all Alfa windows were slow too so I cleaned the connection in the doors as well as the window button itself and it seemed to help. I would suggest not taking the button apart. A bit of spray contact cleaner and some compressed air should do it.
1 - 2 of 2 Posts
