I just replaced the power window cables on both doors on my 1991 Series 4 Spider. It is not an easy job –but- if I can do it, you can do it.
I bought the wire rope, rope stops and cable cutting tool from Amazon and I’ll list them at the end of this article.
Getting the regulator assembly out of the door is not easy because it does not clear the window front guide channel. If you loosen the bolt that attaches the window guide to the bottom of the door it allows that guide to move just enough to let you wiggle and pull the regulator assembly out of the door. You have to pull the regulator like you hate it. That bolt is on the outside of the bottom of the door.
Next, I disassembled the regulator, cleaned and greased it. The old grease was like dried peanut butter and there is no doubt in my mind that it gummed up the regulator. Remove three bolts and lift the top, the gear mechanism, off the regulator assembly. The plate on the gear mechanism can now be removed to expose the gears. This plate is held in place by friction of an O-ring on the shaft. Clean the gears, grease them and put the plate back on.
Clean the cable drum and prepare a length of cable. Cut a piece of cable 126 ¾ inches long. This is the total length of the cable. When you finish the cable, that is when you crimp the rope stops, leave about 3/32 inch of cable sticking out past the end of the rope stop. Each rope stop will use ¼ inch of the cable, leaving an effective cable length of 126 ¼ inches. Note: wire rope cable is difficult to cut and if you don’t have a clean cut the wire rope stop will snag loose strands when you try to put it on the cable and they will not install cleanly. I had to use the tool listed at the end of this article to get a clean cut. I crimped the rope stops onto the cable using my shop vise.
Install and crimp the other end of the cable into the cable drum. Be sure to put the cable guide, the black tube the cable slides through, and guide retainer on the cable before you attach the cable to the cable drum.
Now that both ends are attached to the cable drum, wrap the cable onto the drum. Start with one end and wrap it about 3 wraps onto the drum and then put a zip tie around the drum to hold that cable in place.
Wrap the other end onto the drum so that the free end comes off the drum on the same groove the other cable comes off the drum. Imagine that with the drum turning, one cable wraps on the drum while the other unwraps. Put a zip tie around the drum to hold this cable in place. This will be a little less confusing after looking at the picture after the next two steps.
With those zip ties on the drum to hold the cable secure, reassemble the cable drum onto the regulator assembly making sure the cable loop comes off the drum in the correct orientation to the mounting studs. That is the cable loop has to pass by a specific mounting stud, one cable above the stud and the other below. This will be a little less confusing after looking at the picture after the next step.
Being very careful, hold tension on one of the cables and zip tie it to a mounting stud. Be sure to use the correct stud. While holding tension on the cable, cut and remove the zip tie that was wrapped around that cable on the drum. Be sure to pull that cable tight while you zip tie it to the stud. If the cable slips out of a
groove now is the time to correct that. Use a small pick to get the cable in the correct grooves. Do the same for the other cable and zip tie it to the stud. The purpose of these new zip ties is to hold the cable tight on the drum while you install the regulator assembly into the door. The regulator assembly is now ready to be installed into the door. Note: Others on this forum suggested making a C shape piece out of PVC pipe to hold the cables on the drum and I think that would work if zip ties keep failing for you.
Remove the glass from the door. With the glass removed it is much easier to route the window cable onto the top cable guide rollers. Carefully unbolt the two cable mounting brackets from the bottom of the window glass and lift the glass out of the door. Remember which bracket was the front and rear so you can put them back in the same orientation.
The next thing to do is to install the regulator assembly inside the door. Here is a link to a video showing how to route the cable on a door mock up and also a cable routing picture from the Spider shop manual.
With the regulator in position but not bolted in, route the cable to all the rollers. To get more slack in the cable you can loosen the bolt on the upper roller, the roller with a slot, and push it towards the rear of the door. You can also loosen the two nuts on the plate holding the bottom rollers.
Continued in part 2
Continued in part 2
