The bump bump bump on take off is probably the center bearing support of the driveshaft. The rubber gets soft and lets the shaft bounce around at low rpm.
Ok. Well, lets see a picture of the shifter in reverse and in 1st. No need to take anything apart.I did replace both rubber shifter boots. The console is installed. Do you still want a picture?
Did the PO say how long ago he replaced them?WOW, thanks. I was told the PO replaced the motor mounts, but who knows for sure. Any way to tell visually?
