Hi, i am wondering if someone can give me some advice regarding problems i've got after recently fitting a Pertronix Ignitor.
First of all the car is a 68 roundtail 1300 Junior, standard twin 40 weber carbs.
Replaced existing points in standard Bosch distributor with Pertronix, dizzy cap & rotor are pretty new as are the HT leads, replaced coil with Bosch blue as existing one was very old, plugs replaced mid last year.
The problem, when i start from cold it takes somewhile to get the motor to idle right, i timed the engine according to the manual @ 3deg/1000rpm but of course with unleaded fuel this tends to go out the window so i've advanced it to 10deg, carbs are balanced right with syncrometer and mixture screws 1/2 a turn out which seems the best setting.
Plugs are continually fouling as they did before and whilst it runs fine when warm it is worse at cold than when the points were in, i now have it running on three cylinders only but this may be in an effort to get it to run right, the spark plug on No3 looks bad.
Any tips on the best way to time the engine and how far should you advance it, and any clues why the plugs keep fouling
