1 - 2 of 2 Posts
So I was taking a peek under the S4 yesterday and discovered this rust hole right under the driver's side floor pan. You can touch the sound insulation right through the hole.
Is it just me, or was there supposed to be a rubber cap there?
The hole looks just about perfectly round.
yep, there is a round hole (was something to do when they dipped the cars during production, to let the fluid drain out)...there was then a metal cap pressed in (at least later spiders...maybe earlier had rubber)
yours is rusted because when the car gets wet under the carpet, you cannot just lift out the carpet to dry it off.....you have to dismantle half the bloody interior to remove the 'one piece formed' carpet!;)
you can get rubber plugs that will do the job as well.
1 - 2 of 2 Posts
