I had posted on the brake forum and it was suggested that these might be a GTA item. Can you please add additional information if this is correct. Would like to know mfg. I can not find any markings.
Hi, the caliper you show is the ATE alloy as used on the vented discs of GTAm/GTA with wide body & 13" wheels. Also used on some Porsche 911 models.
Yes, reproduction items are available too.
regards,
Vince.
Vince, Do you know if these had a part number? I am looking for replacement pads and rebuild kits. Thank you.
pads are easy, OKP a.o. has a selection of pads , also it is I think a pad that is used in more calipers. For rebuild kits a porsche parts dealer should be easy to locate, or maybe also OKP.
pads dimension
The pads from 2000 GTV front and 75 TS front will fit
