Hi I have a 1992 Twin Spark engine which appears to need a ring set as I filled with fuel and by the next morning cylinder 1 was empty:(.
Are the rings the same for late 16V twin sparks as the 8V TS sets seem to be a little difficult to get.
thanks.
Chris
Thanks. I will check. On a slightly different note. should there be any lateral movement in the crank at all. there is a tiny-est of movement not really noticeable but you can hear a very slight noise when you try and move the crank.
thanks
Chris
