Ive got a now defunct 1500 motor (playing with superchargers) .Think Ive heard nissan pistons will fit. Has anyone else heard this rumour or am I dreaming?
Don't know about Nissan pistons. However, keep in mind that, depending on the bore class stamped on each cylinder and corresponding piston (A, B, C ...) , pistons are not interchangeable between two cylinders, or between Alfa engines of the same type.
Hi gustav
I belive you are correct in a way, the pistions i think are L28 nissan pistons but i think the compression ratio changes and they may need to modified to clear the valves.
Hope this helps.
