21 - 24 of 24 Posts
Discussion Starter · #22 ·
Sure, I basically stripped it down, removed the old veneer
(which is a thin layer of veneer on a backing panel with
glued plastic locating pins) and then removed the old vinyl.
Purchased the new vinyl at reoriginals, used 3M spray glue
to attach that, copied the pattern from the old pieces.
Took the old veneer and removed the top layer (it just peeled off),
bought some new veneer from rockler.com, cut that to shape
and stuck it to the old backing panel. Be careful here though since the veneer will attempt to curl, lots of weight on top while
it dries seems to help. Five coats of polycrylic finshes the job.
Does anyone know if the plastic trim pieces are still available ?
I'd like to put new ones on to finish the job.
Discussion Starter · #24 ·
Garrett,
Mine had two screws in the sides, the chrome seatbelt loop
and two metal pieces that secure it to the forward console.
I did have to take the seats out to get at the screws though.
21 - 24 of 24 Posts
