141 - 152 of 152 Posts
Here's mine. I've been happily looking at it for 54 years.
$9 Viton seal ……… are you referring to the 8 x 16 x 7 mm seal in the water pump (and gear box for speedometer)? If so where are you getting a Viton version? Order number?
Discussion Starter #143
Carl, not sure what you're referring to above. Maybe another thread?
Did some upkeep on the Spider, checked fluids etc. My presumed trans leak turns out to be a pretty good leak at the back of the engine. At some point it'll have to come out, rebuild, it's been 40+ years since Les Hurlock was last in here. But not yet!
Under the car last week, noticed the condition of the donut. We're all about value around my house, but jeez, I think we got all we could ask from this one. So I changed it yesterday. One of the through-bolts was sort of friction-welded/galled into the metal sleeve in the donut, so that took some work to undo. But in the end all good. Rear trans seal even seems to hold in oil, so I didn't change it.
My question about source and part number of Viton seal was in reply to Gordon's earlier reply:"If it doesn't leak at the tach drive, it's mine. I use a $9 Viton seal in there that keeps them oil leak free. " I guess I should have sent it directly to Gordon. Sorry to side tracking your thread.
The Viton tach drive seals I use, come from Metric Seals in Noblesville Indiana. Measure an old one or (if you can see it) the size is usually cast in the rubber.
Discussion Starter #146
I got a Reinz gasket set from Jon Norman recently and it came with a lip seal that must go to the tach drive.
Discussion Starter #147
So I was taking the Giulietta to Petaluma yesterday to look at a Kaiser Deluxe (don't ask). Five miles down the road it burped/hiccuped, then ran OK again, but it had been running a bit off and I took a second warning to heart. Got off the freeway, idled home, seemed to make a sound a large throttle openings, didn't seem related to rpm. Sounded more like pinging than a mechanical sound. Got home, took the plugs out for a first look, found #3 NGK with the electrode gone. Still firing on that cylinder but not well. I'm guessing the hiccup is when the electrode let go and went out the exhaust. I looked around with a bright light, didn't see any damage in the cylinder. Put new plugs in fired it up, all good. Did a compression test, all about 190, just like when I bought it from Bill Gillham 12 years ago. Whew.
I had the electrodes disappear out of #2&3 plugs on Dad's '57 Spider, new plugs sorted the problem and also good compression all round with no lasting nasties
Bad batch of plugs ?? I bought them from my regular spares outlet who stock reputable brand items.
Glad your Spider is OK
Ciao
Greig
Discussion Starter #149
I had a fine wire plug do this on a Ferrari 308 once, stopped firing on that cylinder. New plug, all good, didn't seem to do any damage.
Discussion Starter #150
So I didn't buy that Kaiser that I went to look at, but I do keep going to Petaluma. My cousin has a 69 2002, needed to go to a BMW shop in Petaluma for engine diagnosis, so we headed up there yesterday, me running chase in the Veloce. Here's a pic approaching the San Rafael Bridge in Pt Richmond. It's not lost on me that I'm using a 60-year-old car as backup for a 51-year-old car. Nice drive up though the 02, cruising at 60 (see speedo) kept the Veloce just below the power band. Bombed back at 70-75, Veloce much happier. Was a beautiful day out.
Discussion Starter #151
So some noises I wasn't crazy about first led to pulling the trans, then what the heck, pulled the engine. Will go through both, see what there is to see. This trans has marginal synchros, has always jumped out of reverse on power, so it will benefit from freshening.
The engine, a leak from the head gasket, burns some oil, some gubbins in the bottom of the oil pan, OK, I don't need more convincing to open up and see what's going on. Les Hurlock maintained this car for decades. I have the head off and the pistons out, other than one-piece Borgo oil rings, looks remarkable inside. Pistons look new, bearings good, head it utterly uncorroded. That's unexpected in a 60-year-old engine. Might be a hone, rings, bearings, back together. We'll see.
Clutch is dated 1970, has essentially no wear. Engine was last apart in 1986 for low compression, looks great so far but I don't have the mains out yet. I have some oversize pistons but may keep it as is. Also will figure out my cam choices. Has stock 101 Veloce in it now, might go with something more modern.
