541 - 560 of 764 Posts
Discussion Starter #541
Once the differential caught wind of what I had in store for it, he got all excited and popped this giant boner (can I say that?):
Discussion Starter #542
The rectangular slots in the metal plate are there to accommodate the aluminum casting blocks on the differential. It helps lock down the plate while it's girdling the sliding block's peg. Getting that peg hole drilled in the precise position with minimal clearance around the peg was no small feat. The diff looks just about ready for the sliding block.
Question is, why is he so mad?
Discussion Starter #543
I think I know why he's mad.
I made that peg out of 1144 steel. It has about twice the tensile and yield strength of mild steel. It's relatively easy to machine; it prefers HSS over carbide cutting bits on the lathe for a smoother finish, and sends off a shower of tiny flaky chips when machined.
But Grade 5 titanium is still better. It's almost always better. Its tensile and yield strengths are higher than 1144 steel, it's way lighter, and will never rust. I happen to have have a thick rod of the stuff, so I remade the peg. Smaller, too, which allows for more meat on the Delrin sliding block so it won't fail.
It resulted in another small cloud of precious titanium shavings. Yes, I'm still saving this stuff.
The Autodelta sliding block system used a special diff casting that was substantially reinforced, and mounted the sliding block on a plate that bolted to the diff with six bolts.
I'll add a pic if I can find it.
Robert
Discussion Starter #547
Thanks, Robert, but I already have those pictures on file. I do a lot of research before I embark on a new project. I know that you can buy AD reproduction diff cases in Al or Mg from Alfaholics. I also thought about welding threaded Al lugs directly onto the case. Back when they were still around, Vintage Prep used to supply a sliding block setup with a bolt-on diff bracket and delrin block/plates. There are a number of options, mine is a hybrid.
I cut and drilled a block of Delrin. The Autodelta pin is about 22 mm diameter, but my Ti version is 19 mm. That allows a little more thickness for the Delrin block, and still allows it to fit in an Autodelta repro yoke. I figure the 19 mm pin is adequate since most Alfa panhard linkages seem to use 12 mm bolts in the spherical bearings, and race mustangs with Watts linkages use a 5/8" (15.8 mm) differential pivot pin.
Since the differential filler hole will remain functional, I need to be able to torque the Ti peg on and off, so I milled some flats on the end to fit a 14 mm wrench. Once I get the yoke mounted and figures for final clearances, I'll use washers to shim the block into position on the peg.
Discussion Starter #549
Neil, I know what you mean. When I first started fabricating things, it was with handtools. I used an angle grinder and a cordless drill to fabricate rearset brackets for my vintage race bikes. I'd also make spacers and bushings by eyeballing where the holes should go, then drilled them by hand. Incredibly sloppy. When I got a drillpress, it was like a revelation, being able to drill holes exactly where you want them. Same goes for a welder; being able to fuse metal took fabrication to another level. Currently, I'm eyeballing plasma cutters. It's the only reasonable way to cut titanium plate.
Back to the project: understanding that the Delrin sliding block is a consumable item, I went ahead and made up several more to have on hand. Swapping them out is a matter of undoing a snap ring. If they fail, I have a back up plan involving a big hunk of titanium.
Discussion Starter #551
You're reading my mind about Swiss-cheesing that plate, Richard. As for making it out of titanium, see my comment above about getting a plasma cutter. I need to save my pennies to get a decent American-made one (I'm dreaming of a Hypertherm 45).
I have now turned my attention to the yoke. I had it and the diagonal struts heat treated to T6 at a Seattle foundry. I like how this race car project exposes me to these industrial processes: waterjet cutting, ceramic coating, foundry...
This yoke piece is currently under the knife to shave off some rough casting excesses. It'll need some drilling as well.
Richard Jemison
Cutting Ti
Plasma cutter for Ti?
Have you watched Titanium burn? While cutting down some 5/16 (SBC)valve heads to Alfa sizes I had the material burning comming off the insert!
I`d suggest a water jet!
Discussion Starter #553
The sliding block components, made from original Autodelta parts, required a fair bit of machining. These are about the biggest things my little machines can work.
I think I can, I think I can...
Discussion Starter #554
Makin' holes
Fenestrated the girdle plate. In Switzerland, they call it "cheesing." (I made that up.)
It was a lot of work to make the plate in the first place, so I was anxious about drilling it full-o-holes. That's where the cheap cab comes into play. Liquid courage. (Shouldn't be doing that when dealing with sharp power tools.)
Discussion Starter #555
I thought the passenger side bracket for the SBPGP (sliding block peg's girdle plate) could use some bolstering against the differential fins. So I machined up some 7075-T6 lugs to shoulder the weight.
Discussion Starter #557
Thanks, Robert. I think I'm stuck somewhere between "Necessity is the mother of invention" and "Idle hands are a devil's workshop."
I've been reading up on plastics, trying to decide on what to use for the yoke's liners. Acetal (Delrin) is very tough, but UHMW (ultra high molecular weight) plastic is very slippery. A lower coefficient of friction is highly desirable in a sliding block set up, whose weak point was the binding of the bronze block against the yoke's steel wear plates. So I went ahead with slippery UHMW, and if it eventually disintegrates, I'll switch to Delrin.
Discussion Starter #558
Hey, it's just about done! Still need to make the steel brace that limits fore/aft movement of the this assembly. I'm also going to mount the trailing arm directly to the chassis sheetmetal, so I'm not using the cross-piece that replaces the T-arm.
Richard Jemison
Questions
Have you test assembled this stuf in the chassis to see if it has clearance for your components behing the diff to clear the chassis box behind the diff?
With the lowered roll center (not a good thing with this or a panhard or watts ) what spring rate are you going to use?
Is your mill the one that attaches to the 9.8.5 x 16 bench lathe? I have that lathe and have been thinking about getting one. How do you like it and would you buy another one? I've been able to do so many things with my lathe a mill could do so much more. Thanks for the great documentation of your top notch work!
