Can anyone help with some pictures and tips about mounting a Facet Silver Top electric fuel pump in my 71 Spider (converted to Webers)?
My Spider has been bogging at about 5500 rpm on steady acceleration. I have fresh filters, a coated tank, a Malpassi Filter King adjusted to 3 PSI, fresh points, and fresh plugs. Webers were tuned a few months ago by a pro but the bogging remains.
I also have a small squarish electric pump that I suspect is probably 15 or more years old... probably part of the PO-purchased Weber conversion kit. Having ticked off the other possibilities above, I suspect this small pump runs out of steam (OK fuel pressure) under the load of acceleration. Besides my mistress demanded something for Christmas
, so I purchased her the pump along with a mounting kit and the 90 degree fuel line hookups. Haven't bought anything for the wife yet though
The instructions which come with the new pump 'recommend' mounting it vertically with the input from the tank at the bottom and the output at the top. I'd planned to mount it horizontally, in the right rear of the car where the current pump resides, with the fuel input closest to the tank. It had never occurred to me to consider mounting the pump vertically (which I suspect would be a small PITA) until I looked at the instructions. I'd prefer to mount it horizontally of course .
Additionally, I haven't pulled the old pump yet (it's 35 degrees today!) and so I don't know how the bracket on the Silver Top lines up with any brackets or mounting points on the car. I'd appreciate any advice and experiences you guys could give.
Finally, I bought the Silver Top as it was recommended here as the best low pressure pump for Weber Converted cars. I've read that the fuel pressure is 2 - 5 psi. Is this adjustable? If so, how? Do I even need to worry about that since I have the Malpassi pressure regulator?
Thanks!
Lokki
Thanks!
Lokki
