1 - 5 of 5 Posts
Do I need a pickle fork for redoing my front suspension on my 87 spider? If so, is there a certain kind or size I would need for an 87 spider?
pjn
Not sure of the exact size. You may need to measure the ball joints with a caliper if you decide to use the pickle fork. I have used both a pickle fork and a ball joint remover as referenced in the previous post. The latter is a safer bet with regard to preventing tears in the ball joints and it is easier to use in tight spots.
Just for reference there are pickling fork attachments for air hammers if you have a compressor. Just saw one the other day at my local Sears.
A pickle fork works well, but expect damage to the joint boot. If you're replacing it, it really doesn't matter anyway.
JC Whiney have a couple of joint separators at a fraction of the cost of the IAP model. Buy them both and you will be able to separate ball joints and tie rod ends without damaging them.
Ed Prytherch
74 GTV (3 days until it moves to Toronto)
79 Spider - about to get almost all my attention
88 Verde - daily driver
1 - 5 of 5 Posts
