hi all
i have 74 2liter in a 77 bod. with del ortos in it..i have puchased pertronix and installed..seams to run ok..
the question i have is should i have a ballast resitor in there or not..any help would go a long way...thanks
Ballast with Pertronix?
The question of ballast or not, depends on what coil you're using. Pertronix sells a nice high voltage coil or we often use a Bosch Blue Coil. Neither of these need a ballast. If you're using an original style Marelli with the piggybacked ballast, you will want to leave it in place.
KG
