1 - 5 of 5 Posts
I have purchased Penrite for my steering box which previouly had been filled with a mixture of 90 weight oil and grease. I would like to clean out the box before I fill it. Can I simply remove the four bolts holding on the top of the steering box? I know some of you are going to suggest that I replace the seal. I intend to do this along with some other pretty major fixes summer of 2022 when the car is not driveable anyway. ( I am in South Texas Winter is top down weather here. Summer is park it time )
Yes, that's doable in the car, though it might still be tough to get all the oil and grease out even with the top cover removed.
I'd take the small football-shaped cover, shims, and spring off first, then remove the top cover.
Thanks for the responce ( even though i misspelled Steering in the title) A good Saturday project.
Discussion Starter · #5 ·
It was leaking pretty badly. Anyway its all finished. Getting the old goop out wasn't as bad as you would imagine. I siphoned as much as I could then pulled the most rest out using a 1' paint brush. When i had most of it out i hooked up my compressor and blew the last 10% to the bottom and grabbed it up with the paint brush. The only thing i moved out of the way was the radiator overflow tank.
1 - 5 of 5 Posts
